Click Here for Demolition derby 2 About the Game: Demolition Derby - Saints Row 2 Guide and Walkthrough Saints Row 2 - Demolition Derby - Saints Row 2 Guide, walkthrough, faq, unlockables, cheats, videos - Demolition Derby. There is only one instance of this activity, and it’s located in Frat Row, which is part of the Stilwater University District. At the start of each level, you first must choose which vehicle to use in the derby from a limited roster. You can then upgrade the vehicle of your choice by allocating points into three different areas: offense, defence, and speed. Completing levels adds more upgrade points. Level 1 upgrades cost a single point, while level 2 upgrades require three. To progress to the next level, you must inflict the dollar worth of damage indicted in the upper-left corner of the screen. The amount required to move on to the next level increases as you progress. Simply surviving is not enough, even if yours is the last car in the ring, you must meet the damage requirement to complete the level. Cause a vehicle to explode and you’ll earn a $500 explosion bonus. The Ruckus is a well-balanced vehicle that can easily carry you to the final stage. When each level begins, start towards the other cars in the distance, activate Nitro, and try to ram into the other contenders. The trick here is to keep moving, as sitting idly by leaves you at the mercy of the other drivers. Hitting a car on its side inflicts the most damage. Circle around the arena until you spot an opponent, then use the nitrous and try to ram them. Your first upgrade should be to speed, followed by offense. Upgrade the speed attribute to level 2 when you have enough points, and fill out the rest following that. As with most of the other activities, the first five levels are a cakewalk, however things do become difficult at the sixth and final level. Use the Ruckus until the sixth stage, at which point you’ll want to switch to the Rampage. The Rampage is all speed, and that’s exactly what you need to meet the final level’s damage requirement of $30,000. You have to get in there and inflict as much damage as possible before all of the vehicles are destroyed by the other combatants. Completing all six levels of the Demo Derby activity unlocks the “Demolition Man” achievement on the Xbox 360 version. The upgraded Demo Derby vehicles are also added to your crib garage. Stilwater University District (Frat Row) Rewards : Complete Level 3 - 5% Discount at Mechanic Shops. Complete Level 6 - 15% Discount at Mechanic Shops. demolition derby 2 hack
