SELECT data_key, data_value
FROM xf_data_registry
Run Time: 0.000223
SELECT cache_value
Params: 1
Run Time: 0.000064
SELECT thread.*
NULL AS thread_read_date,
0 AS thread_reply_banned,
0 AS thread_is_watched,
FROM xf_thread AS thread
LEFT JOIN xf_user AS user ON
WHERE thread.thread_id = ?
Params: 1398
Run Time: 0.000274
SELECT node.*, forum.*
NULL AS forum_read_date
FROM xf_forum AS forum
WHERE node.node_id = ?
Params: 21
Run Time: 0.000213
SELECT post.*
user_profile.*,
user_privacy.*,
0 AS like_date
FROM xf_post AS post
(user.user_id = post.user_id)
WHERE post.thread_id = ?
Params: 1398
Run Time: 0.000992
SIMPLE | post | range | thread_id_post_date,thread_id_position | thread_id_position | 8 | | 19 | Using where; Using filesort |
SIMPLE | session_activity | ref | PRIMARY | PRIMARY | 4 | poloclub.post.user_id | 12 | |
(thread_id)
VALUES
Params: 1398
Run Time: 0.000078
Params: 9bfe073363bad11ffe6534e59444214f, , 1714081430
Run Time: 0.072846
VALUES
ON DUPLICATE KEY UPDATE
ip = VALUES(ip),
params = VALUES(params),
robot_key = VALUES(robot_key)
Params: 0, , , XenForo_ControllerPublic_Thread, Index, valid, thread_id=1398, 1714077830,
Run Time: 0.000162
Run Time: 0.000098
SELECT session_activity.*
user.*
WHERE (session_activity.view_date > 1714076930)
Run Time: 0.000887
SIMPLE | session_activity | range | view_date | view_date | 4 | | 150 | Using where |
