SELECT data_key, data_value
FROM xf_data_registry
Run Time: 0.000189
SELECT cache_value
Params: 1
Run Time: 0.000065
SELECT thread.*
NULL AS thread_read_date,
0 AS thread_reply_banned,
0 AS thread_is_watched,
FROM xf_thread AS thread
LEFT JOIN xf_user AS user ON
WHERE thread.thread_id = ?
Params: 4499
Run Time: 0.000283
SELECT node.*, forum.*
NULL AS forum_read_date
FROM xf_forum AS forum
WHERE node.node_id = ?
Params: 47
Run Time: 0.000180
SELECT post.*
user_profile.*,
user_privacy.*,
0 AS like_date
FROM xf_post AS post
(user.user_id = post.user_id)
WHERE post.thread_id = ?
Params: 4499
Run Time: 0.001204
SIMPLE | post | range | thread_id_post_date,thread_id_position | thread_id_position | 8 | | 19 | Using where; Using filesort |
(thread_id)
VALUES
Params: 4499
Run Time: 0.000063
Params: eefe93763d111302f745ebae67d53f77, , 1714147497
Run Time: 0.061346
VALUES
ON DUPLICATE KEY UPDATE
ip = VALUES(ip),
params = VALUES(params),
robot_key = VALUES(robot_key)
Params: 0, , , XenForo_ControllerPublic_Thread, Index, valid, thread_id=4499, 1714143897,
Run Time: 0.000448
Run Time: 0.000075
SELECT session_activity.*
user.*
WHERE (session_activity.view_date > 1714142997)
Run Time: 0.000815
SIMPLE | session_activity | range | view_date | view_date | 4 | | 231 | Using where |
