SELECT data_key, data_value
FROM xf_data_registry
Run Time: 0.000218
SELECT cache_value
Params: 1
Run Time: 0.000074
SELECT thread.*
NULL AS thread_read_date,
0 AS thread_reply_banned,
0 AS thread_is_watched,
FROM xf_thread AS thread
LEFT JOIN xf_user AS user ON
WHERE thread.thread_id = ?
Params: 11510
Run Time: 0.000247
SELECT node.*, forum.*
NULL AS forum_read_date
FROM xf_forum AS forum
WHERE node.node_id = ?
Params: 22
Run Time: 0.000159
SELECT post.*
user_profile.*,
user_privacy.*,
0 AS like_date
FROM xf_post AS post
(user.user_id = post.user_id)
WHERE post.thread_id = ?
Params: 11510
Run Time: 0.000817
SIMPLE | post | ref | thread_id_post_date,thread_id_position | thread_id_post_date | 4 | const | 11 | Using where; Using filesort |
(thread_id)
VALUES
Params: 11510
Run Time: 0.000092
Params: bdf3bd48f8cc215860f2339657b555c4, , 1713607029
Run Time: 0.053497
VALUES
ON DUPLICATE KEY UPDATE
ip = VALUES(ip),
params = VALUES(params),
robot_key = VALUES(robot_key)
Params: 0, , , XenForo_ControllerPublic_Thread, Index, valid, thread_id=11510, 1713603429,
Run Time: 0.000214
Run Time: 0.000086
SELECT session_activity.*
user.*
WHERE (session_activity.view_date > 1713602529)
Run Time: 0.000647
SIMPLE | session_activity | range | view_date | view_date | 4 | | 189 | Using where |
