SELECT data_key, data_value
FROM xf_data_registry
Run Time: 0.000225
SELECT cache_value
Params: 1
Run Time: 0.000087
SELECT thread.*
NULL AS thread_read_date,
0 AS thread_reply_banned,
0 AS thread_is_watched,
FROM xf_thread AS thread
LEFT JOIN xf_user AS user ON
WHERE thread.thread_id = ?
Params: 8495
Run Time: 0.000535
SELECT node.*, forum.*
NULL AS forum_read_date
FROM xf_forum AS forum
WHERE node.node_id = ?
Params: 27
Run Time: 0.000162
SELECT post.*
user_profile.*,
user_privacy.*,
0 AS like_date
FROM xf_post AS post
(user.user_id = post.user_id)
WHERE post.thread_id = ?
Params: 8495
Run Time: 0.000919
SIMPLE | post | ref | thread_id_post_date,thread_id_position | thread_id_post_date | 4 | const | 18 | Using where; Using filesort |
(thread_id)
VALUES
Params: 8495
Run Time: 0.000056
Params: e920fe9fc635e6bec33d84c91ad2c48e, , 1714810384
Run Time: 0.333106
VALUES
ON DUPLICATE KEY UPDATE
ip = VALUES(ip),
params = VALUES(params),
robot_key = VALUES(robot_key)
Params: 0, , , XenForo_ControllerPublic_Thread, Index, valid, thread_id=8495, 1714806784,
Run Time: 0.000574
Run Time: 0.000106
SELECT session_activity.*
user.*
WHERE (session_activity.view_date > 1714805884)
Run Time: 0.000996
SIMPLE | session_activity | range | view_date | view_date | 4 | | 49 | Using where |
